Hi All,
First post, hoping for a quick reply. I am not a Linux guru or a router firmware expert so I am looking for an idiots guide on how to configure dd-wrt to connect to a SKY fibre internet service via a BT Openreach model. The modem was part of the original SKY setup which included an Old SageCom router that I am hoping to replace with my R7800 with dd-wrt installed.
So to date I have done:
1. Obtained my SKY broadband username and password from DHCP Discovery packets using Wireshark
2. Successfully flashed the R7800 with latest DD-WRT Kong Mod
Question is what do I have to do next to configure dd-wrt to connect to the SKY Fibre Internet services an step by step idiot guide would be much appreciated telling me the tabs and field setting I need to access and change to make it work
SKY uses DHCP authentication (MER)
many thanks
Ded
WoW! thx for all the help guys its overwhelming to find such bright group of people so willing to help out, oh look its a tmbleweed blowing across my post, anyway thanks I know you did your best
