Hi All,
I notice there's a new Kong Mod firmware update for the R7000 (DD-WRT Kong Mod for NETGEAR R7000 2016-12-02)
Is there any information on the update? A changelog of any sort?
AntonK
Hi All,
AntonK
Change log is on the download site, and in the zip file when you dl it.
Hi EventHorizon,
I don't see a changelog in either place you suggest, here in the downloads section (in the .zip file) or here:
Can you point me to it with a link?
AntonK
HMM I see transmission guide in OP states to put it in /OPT partition, but mine has been running from the /JFFS one, since thats what the browser gui had it set to standard, would that be lead to any issues?
I guess you are right there is no change log. I just updated to most recent firmware today and there was no change log.. Sorry about that.
