Problem after flashing Tomato
7 posts / 0 new
Meller74
I probably made a huge mistake by flashing initial AdvancedTomato image directly from DD-WRT on my R6300v2.
I checked clear settings and now I can ping the router and connect with it within the browser, but my login and password don’t work anymore.
I tried also the default logins and passwords of DD-WRT and Tomato, but no luck so far…
Meller74
Is there a way to use TFTP2
Is there a way to use TFTP2 to flash the router like on my old WNDR3700v2? On the WNDR3700v2 I have to push the reset button for 30 seconds while booting and then I can flash with TFTP2 any suitable rom without a problem, but doesn't seem to work on the R6300v2...
budman
Meller74,
Meller74,
       Did you ever solve the login issue? I flashed mine using the same build and defaults as you stated above and came up with the same issue. I do not have the correct username and password to login and also tried the usual default username and passwords with no luck. PLEASE.. if you aquired any new information on this topic i'd appreciate anything new to this issue.
        Budman
budman
Bump   help please.
Bump   help please.
Meller74
Unfortunately I did not solve
Unfortunately I did not solve the issue. I bought a new Access Point.
budman
Has anyone come up with a solution,
Any help is greatly appreciated
Thanks in Advance!
EricGRIT09
Do the following:
Do the following:
Telnet to the router IP using for 233.
Type "nvram get http_username" and "nvram get http_passwd"
