R6700v2 router Kong build?
3 posts / 0 new
Firestw152
I just purchased the R6700 but before I started to flash it with ddwrt I noticed on the box it said V2 and wanted to make sure that its the same as the v1 so I don't brick my router trying to flash Kong's latest build. I bought the R6700 specically for kongs ddwrt and I really hope I can install it on the v2. Please let me know.
Peter Redmer
I'm not aware of a Kong build
I'm not aware of a Kong build that supports the R6700v2 directly, this was brought up here earlier too:
https://www.myopenrouter.com/forum/r6700v2
On Kong's site, generally "V2" is specifically called out.
Firestw152
What do you mean its called
What do you mean its called out, that he does not support it?
