Sorry, I am not sure about the R7500v2. However, I can confirm those PIA instructions work successfully for the R8500 on dd-wrt.K3_R8500_20170321 firmware.
Yes dd-wrt up and running great with Kong's builds. I went back to r31800m given some folks mentioned its stability vs the latest. I am working with PIA a bit on this as well but if anyone has had success with r7500v2 openvpn I would be interested in hearing.
One thing I am finding is its hard to get the time set on this build using NTP. Has anyone experienced similar?
Are you using DD-WRT for the R7500v2?
And did you follow the instructions here from PIA?
https://www.privateinternetaccess.com/pages/client-support/dd-wrt-openvpn
