Hi, I am new to custom firmware. Anyway, I flashed Tomato Shibby initial 140 and then tomato-R8000-ARM--140-AIO-64K, but I can't see all the menus about Captive portal, USB setup, etc. The only item there is VPN setup. What did I do wrong? I tried to reflash it and delete NVRAM, but to no avail.
Did you flash with the AIO version or just the VPN version?
I flashed tomato-R8000-1.28.ARM--140-initial-64K.chk initially from the netgear FW and then I tried to flash tomato-R8000-ARM--140-AIO-64K.trx (20mb) from the Tomato FW web interface, but that doesn't seem to be working? Can I try e.g. v139 AIO or do I have to flash initial for 139 first?
Hmm, not sure what has happened, but I just reopened the web interface (wanted to flash v138) and the buttons are there. I might not have ever closed the original page.
