Hi all,
I notice in the downloads for the Shibby FW it says there needs to be an initial update before dropping the proper payload onto the router. Is this only for a stock FW? Does this still need to be done if the router is switching from DD-WRT?
Cheers
You need to revert to stock. Then flash the initial FW once this has completed then flash the full AIO Fw,
