new versions of fw
4 posts / 0 new
lagunajim
new versions of fw
Hi.  Forgive the newb question -- are we likely to see updates for this router as time goes on, especially when it isn't so new and is therefore more in circulation?
The current Kong version is good, but it could use some updating, especially in the WiFi channel selection area.  "Auto" doesn't seem to work, and manually I can select channels but the extension channels drop-down doesn't seem to correlate very well with the primary manual channel selection.
Other than that, I have an IPv6 issue where I lose ipv6 connectivity about every 48 hours -- so I will probably set the router to auto-reboot every 24.
Is there a place I should report the ipv6 issue for review by kong?
Thanks/jim
MyOpenRouter Team
Kong's build for the R9000
Kong's build for the R9000 was just updated yesterday :) Check the downloads section and have fun. You can feel free to send Kong a private message to report any issues.
cybrex
Jim, have you seen this?
http://dd-wrt.com/wiki/index.php/QCA_wireless_settings
I followed the recommended settings on my router, and it all seems a-okay. Can't help you on the FW side of things - but like the MyOpenRouter team mentioned, Kong just released an update.
cybrex
lagunajim
Thanks guys for the replies.
Thanks guys for the replies.  [I have to make sure I turn on a notification when people reply -- apparently I don't have that on now since I didn't get notified of your replies and just happened to see them now.]
I'm going to load the new release and see how it goes.  Thanks again for your replies! /jim
