I consider buying Netgear R7800 router, I have read that Voxel firmware is much faster as it is a custom version of the stock image and supports Netgear's HW accelerations while DD WRT doesn't.
My question is: is it possible to install additional linux packages (for example like: DD-WRT's ipkg) on Voxel's custom firmware?
If so - where can I see the list of packages?
The most important package that I need is: knock daemon.
Thank you very much in advance,
Best,
Shuki
It is possible to use Entware-3x (with USB disk). How to install: read my readme List is available when you click ENTWARE.
knockd is available:
https://www.voxel-firmware.com/Downloads/Voxel/html/index.html
This is really great stuff... thank you very much!
