Unable to connect Guest Network says "Password incorrect"
4 posts / 0 new
Pebsuk
morbus
with the current firmware I also have the problem. I am back on DD-WRT firmware for Netgear R7000 Based on revision 28514. Everything works well.
morbus
Same message under the newest
Same message under the newest firmware.
morbus
After restarting the router
After restarting the router everything works fine.
