R7000 .bin missing from 2017 November builds?
2 posts / 0 new
pacmanic
I have DD-WRT already installed on an R7000, and wanted to upgrade to the 2017 November builds.  In the desipro.de page, there is an R7000 .chk build, but no R7000 .bin for upgrades.  There is an R7000P .bin file however.  I presume I should not upgrade using the P version?  Or is it compatible?
If not, where is the best place to find the previous KONG build for R7000?  The desipro.de pages only have current versions.
DD-WRT Kong Mod for NETGEAR R7000 (2017-11-01 CHK)
https://www.myopenrouter.com/download/dd-wrt-kong-mod-netgear-r7000-2017-11-01-chk
For .BIN files for upgrade from previous version of DD-WRT:
Thanks for any advice.
pacmanic
I answered my own question.
I answered my own question.  On the Supported Models page, dd-wrt.v24-K3_AC_ARM_STD.bin supports the R7000.  I upgraded with this *STD build without issue.  I was just confused by the lack of an R7000 specific bin.
http://www.desipro.de/ddwrt/K3-AC-Arm/Supported%20Models
Build dd-wrt.v24-K3_AC_ARM_STD.bin supports:
ASUS_AC56U
ASUS AC67U
ASUS AC68U
BUFFALO WZR900DHP
BUFFALO WZR1750
BUFFALO WXR1900DHP
DLINK DIR868
DLINK DIR860
DLINK DIR880
LINKSYS EA6350
LINKSYS EA6400
LINKSYS EA6700
LINKSYS EA6900
NETGEAR AC1450
NETGEAR R6250
NETGEAR R6300V2
NETGEAR R7000
