I have NordVPN and i've loaded the Open vpn gui and tested the speed and then i configured the router for open vpn on the same serverd. (not at the same time)
I have 100Mbps service.
I got 80Mbps when useing the GUI on the pc.
I got 20Mbps when the open vpn client was configured on my router.
I have the latest version of tomato loaded on my R7000.
My pc is a AMD 4300 quad core 3.8 mhz 8gig ram and a $350 graphics card.
could the difference be that the pc can encryped/decrypt faster then the router?
I'm not at an IT level but have build and setup my own routers for years.
R7800 is 3 times faster than R7000 running vpn
That's funny. i just got back from bestbuy with a R7800. But now i can't find support for it from tomato or DD-WRT. Can you tell me what support there is for it please.
Never mind. i just noticed there are more pages on the download page and a search tab. I see the firmware. thanks
Hey T,
Did the R7800 performance meet your expectations? Can you post the numbers for this router for the VPN client throughput speeds?
