Kong or DD-WRT firmware for newbee in order to use NordVPN on a R8500
4 posts / 0 new
gadencourt
gadencourt's picture
Hi
I'm french and totaly newbee on that stuff. I gave a try on my old R6300 and I succeed put inside DD-WRT. So I understand how to read threads and put a new firmware in a router. ;-)
But, I'm totaly lost on different versions of firmwares.
Could somebody help me finding a stable firmware for my new R8500 ? I would much appreciate avoid to brick it, as I'm affraid to unbrick it in case of issues.
It's very important to me to be able to use OpenVPN and 2.4 and 5Ghz WiFi and no loose speed in ADSL or WIFI.
Regards
Philippe
jfosella
jfosella's picture
I've been using Kongs latest
I've been using Kongs latest version for a couple of months now without any issues. https://www.myopenrouter.com/download/dd-wrt-kong-mod-netgear-r8500-2017...
gadencourt
Thank's for your help. And
Thank's for your help. And which file (*.bin) do you use fist ? HAve you done a 30-30-30 reset each time or which reset have you done ?
gadencourt
Erro. I have taken
Erro. I have taken
dd-wrt.K3_R8500.chk
but which *.bin file I have to take after that ?
