WNR3500Lv2 Advanced Tomato - Cannot Connect
4 posts / 0 new
jz32300
Hi
I probably did something stupid.
I flashed my Netgear WNR3500Lv2 with this firmware:
tomato-Netgear-3500Lv2-K26USB-1.28.AT-RT-N5x--3.3-138-AIO.chk
Everything seemed to go fine, but once rebooted I am unable to connect to it by either Ethernet or WiFi.
Ethernet just fails and WiFi asks for my password and then refuses it.
Is there any way I can recover from this situation?
Many thanks
Clive
574659522
Did you every try to clean
Did you every try to clean the nvram with TTL?
Eleusis
Exact same problem with
tomato-Netgear-3500Lv2-K26USB-1.28.AT-RT-N5x--3.5-140-AIO.chk
Anything I can try without TTL?  I'd rather just return it to Amazon :-/
Eleusis
Nevermind, I did the 30/30/30
Nevermind, I did the 30/30/30 reset and it worked.  Woot! :-D
