Hello all,
I did try Kong's build from 14.02 and I am using VPN Astrill and there applet for connecting to there VPN servers. And indeed it does work. However, when I enable the VPN and I want to login to the Router it is not possible, It seems that DD-WRT doesn't recognize the router's IP address as such and it is going thru VPN to find the router's own IP address. In order to connect to the router, I needed to turn off and on the router, so VPN connection was lost. I haven't tried all latest versions of Kong's build, so I wend back way back to official DD-WRT site and downloaded R33772 and here I know at least it is working correctly.
I wend all the way back as I noticed that after that, not sure which version it started, but the reaction time in the firmware was slow and some versions, I couldn't get the 5G to propper work.
Does anyone has any idea about this Astrill's problem or is this common with the new builds??
Hans
I have the same issue and if connect by ssh and restart the http service, you will be able to access the web interface again.
once you stop astrill you need to do it again. you don't need to restart the router.
Hello Jackdaniel,
Thanks for your reply. I will try this when I will upgrade to the Kong's new FW. However, I think this isn't exactly the way to do. As in FW R33772 (not Kong's) it is working as I think it should be.
@Kong,
Can you please check this??
Hans
I see the post is old. But, I want to let you know that the issue can be with the router applet
(VPN)
