I am currently running Kong Mod from 2015. Tried Googling and cannot find anything newer for WNR3500Lv2. Anyone know of a more current firmware from Kong? Thanks in advance. Great website!
- waste of time 5 days 20 hours ago
- Hope this helps.... 2 weeks 6 days ago
- I have been a diehard nether 3 weeks 6 days ago
- Have you fixed this problem? 1 month 5 days ago
A lot of the "older" devices simply aren't supported any more. I have a WNR4500 and I can't update it either. The issue is that the older devices simply don't function right any more with the newer versions of Linux (I believe only kernel 3.x is supported for older devices, not the newer 4.x kernels). Trying to run a 4.x kernel on these devices causes erratic behavior, restarts and slow performance. It's your call to use it in some fashion or spend some $ on an upgrade.
