D7000 Region change from US/NA to WW/Australia
2 posts / 0 new
luckycom
Hi
I'm trying to change the region on the Netgrear D7000
I can get it to work by the following
http://192.168.0.1/setup.cgi?todo=debug   "this enables telnet"
telnet 192.168.0.1 with usename user & password password
cd www  "changing folder to the web pages in www
sed -i 's/@wiz_country#/WW/g' *.htm   "replace are CGI lookups for @wiz_contry" to say "WW"
sed -i 's/@wiz_country#/WW/g' *.html
sed -i 's/@netgear_region#/WW/g' *.htm  "replace are CGI lookups for "@netgear_region#" to say "WW"
sed -i 's/@netgear_region#/WW/g' *.html
sed -i 's/@h_WRegion#/Australia/g' *.htm "replace are CGI lookups for "@h_WRegion#" to say "Australia" just so the wifi region stop chnage to US
sed -i 's/@h_WRegion#/Australia/g' *.html
this will get the D7000 to think it's in australia & let my connect the  ISP's in my region & configure my wifi
but  it's only good until i reflash the firmware & then i have to do it all agian
I'm after a way to presently change it to an :WW: model
luckycom
To change the region on a
To change the region on a D7000
in a web browser go to http://192.168.0.1/setup.cgi?todo=debug
this enables telnet
telnet in the router using normal username & password
type "sc_private_cmd get region" to get your current region
for me "sc_private_cmd set region WW" will set it for me in australia
this was done using firmware "V1.0.1.68_1.0.1",firefox & putty
