It is possible update r6200v2 to current Kong
3 posts / 0 new
bushant
bushant's picture
It is possible to update from https://www.myopenrouter.com/download/dd-wrt-firmware-netgear-r6200-v2-7...
to current Kong firmware from here: http://www.desipro.de/ddwrt/K3-AC-Arm/dd-wrt.v24-K3_AC_ARM_STD.bin.
However after flashing to Kong the only way to update or downgrade is by trying to flash via webgui which results in soft brick. Then tftp the 7-aug-2014 back then flash the desired build. Just sharing in case anyone is interested.
wgsofjan29
wgsofjan29's picture
wgsofjan29
Sorry, wrong link. Thought
Sorry, wrong link. Thought you needed 6400v2. Check this directory. http://www.desipro.de/ddwrt/K3-AC-Arm/TEST/
