Kong Mod for NETGEAR R9000 Updated for 2019
For those of you that are using the R9000 Nighthawk - there is an update created by Kong to get you started in the new year!
Download the latest DD-WRT Kong Mod for R9000 Updates in our Download section!
(Note for new users: If you're just trying out the Kong version of DD-WRT on your R9000, you will need to flash the initial build first, then the DD_WRT BIN. See the release notes in the downloads for more information.)
EventHorizon
EventHorizon's picture
The downloads on the
The downloads on the myopenrouter.com side still show 12/26 in the description of the DL, but it shows uploaded on the date suggested... Has anyone checked to see if it's the right binary?
MyOpenRouter Team
MyOpenRouter Team's picture
These are correct -- with the
These are correct -- with the craziness of the holidays in December this upload was a bit off schedule.
EventHorizon
Thanks, this clears things up
Thanks, this clears things up, when I downloaded the last firmware I downloaded the most recent version on his server (which was newer than the post here at the time) but now they are in sync! Oh well, I flashed it twice to ensure it would stick! (teach me to look closer at my .bins!) ;)
jfosella
jfosella's picture
I had to revert back to the
I had to revert back to the previous version as this one caused my openvpn client connection with Tourguard to fail. Somthing about a TLS error.
jfosella
jfosella's picture
 "RECONNECTING tls-error"
