Loaded "DD-WRT v3.0-r36070M kongac (05/31/18)" & now I can't backup
3 posts / 0 new
calleng
Upgraded my Netgear R6300v2 to "DD-WRT v3.0-r36070M kongac (05/31/18)" today. When I try to Backup I get the following error:
404 Not Found
File nvrambak_r36070M_R6300v2 not found.
What steps should I take to correct this error?
callengodfrey
calleng
I still have this problem on
I still have this problem on two separate R6300v2 routers (running as APs). Does no one have an answer?
NHS2008
Did you fix it?
Did you fix it?
