R7000 Flash Back From Tomato Bricked
4 posts / 0 new
fuesting
I was running the latest Advanced Tomato Shibby Mod on my R7000 but decided to flash back to Netgears.  I followed his instructions here.
https://www.youtube.com/watch?v=rNIpBJPRogY
I got as far as flashing it with the r7000-back-to-ofw.trx file.  Upon reboot lights all flash looking good, I get 3-4 pings from 192.168.1.1, but then they die.  The power and ethernet port lights are the only ones lit.  This same behavior is repeatable by power cycles the router.  I've tried the 30/30/30 process multiple times, sometimes a lot longer.  Not sure where to go from here.
Any suggestions would be greatly appreciated.
Thanks, Jeff
fuesting
Anyone have a suggestion on
Anyone have a suggestion on where to go with this?  Thanks!
mrdon213
power on the router, press
power on the router, press and hold the reset button for 20 seconds then let boot. If it does not come up turn power back off then on again. Most likley nvram was nor erased.
fuesting
Thanks Mr. Don.  I've tried
Thanks Mr. Don.  I've tried all kinds of pressing reset in different intervals and for different periods of time.  No dice.
