*** Dummys Guide to R7000P firmware *****
2 posts / 0 new
Mat-Rix
NightHawk R7000P(AC2300)
OEM Stock standard router brand new out of the box.
OEM R7000P factory installed firmware version : V1.3.1.64_10.1.36
Can any one assist with step-by-step instructions to flash this new router to
DD-WRT to allow NORDVPN (OpenVPN) firmware to work on this hardware.
----------------------- Step by Step -------------------
Step 1. I login to the router |admin|setup and clear the router back to factory settings.
Step 2. Do I down grade the current OEM version of firmware to a lower version ?
Example : R7000P-V1.0.0.44_1.0.27.zip
Step 3. Do I need to pre-flash with a boot loader version of Kong firmware.
Example: factory-to-dd-wrt-chk
netgear-r7000p-webflash.bin
Step 4. Do I flash with DD-WRT Kong firmware after step 3 preflash?
Example dd-wrt.K3_R7000p.chk
Step 5. Do I reset the router after the new DD-WRT firmware versions is installed?
Step 6. Configure the new DD-WRT firmware settings to OPENVPN
coeurdelionn
Just flash factory to DD-wrt
Just flash factory to DD-wrt .Chk file from ftp: DON"T USE BIN file.
ftp://ftp.dd-wrt.com/betas/2020/10-13-2020-r44538/netgear-r7000P/
