In case you have bricked your unit, or in case you need more debugging info from your router you can setup a serial console.
Prerequisites for this procedure:
- 1 x Router either R7000/R6300v2/R6250 which have the same serial connection pins on board
- 1 x Ethernet cable if you want to flash a new firmware in recovery mode
- 1 x USB-TTL 3.3 V adapter cable e.g. FTDI TTL-232R-3V3
- 1 x appropriate Screewdrivers
- Windows or Linux with installed TFTP client
- Windows or Linux with installed serial client e.g. Putty,Minicom
This article does not cover taking apart the routers, this is fairly easy and should not cause any trouble even for beginners. The guide applies to the R7000, R6300v2 and R6250 from NETGEAR, although pictures from the R7000 are shown.
After you open up the case you can start connecting your USB-TTL Adapter. The picture below displays the pins and how you connect them to the serial adapter. In my case, I added a 3.5" stereo jack for easier connecting. This way it can be connected without the need to open it up again. Make sure you read the documentation of your serial adapter; it will tell you which pin needs to be connected to GND/TX/RX.
Once you hook up the serial adapter you can install and setup your serial communication program.. If you are using PuTTY, you can just use the guide from the older debricking guide for the WNR3500L:
http://myopenrouter.com/article/how-debrick-your-wnr3500lv2-using-window...
If you are on Linux, you might want to use minicom. See minicom guide:
http://mstempin.free.fr/linux-ipaq/html/minicom-setup.html
Serial line: /dev/ttyUSB0
Speed: 115200
Stopbits: 8-N-1
Once your serial communication program is set up, start hooking up your TTL adapter. In order to flash a new firmware to the router you need to attach an ethernet cable to one of the switch ports. See picture below.
The default IP of you router is 192.168.1.1, thus you need to setup your computer's ethernet adapter to use an IP in the same network e.g. 192.168.1.2. If you have attached your ethernet cable and setup your computers IP you are now ready to power on your router.
You should see the following messages when you router starts booting:
Once you see these messages start pressing CTRL-C. If everything works out the boot process should stop at the CFE> prompt. Now type tftpd followed by enter. The routers power led will be flashing which signals it is ready for a fw upload via tftp client.
If you are on Windows, just follow this guide to flash a new image via tftp client:
http://myopenrouter.com/article/how-debrick-your-netgear-wnr3500l-using-...
On Linux you can use the following command:
tftp -m binary 192.168.1.1 -c put
e.g.:
tftp -m binary 192.168.1.1 -c put dd-wrt.K3_R7000.chk
After the new firmware is transferred, the router will start flashing and rebooting the unit automatically. You will be able to follow the whole boot process in your serial communication program.
After buying a different cable I can confirm that was the reason for my distorted bootlog, i believe. I do suggest not buying a cheap cable. Also, make sure it is FTDI TTL-232R-3V3, and not FTDI TTL-232RL-3V3
I successfully managed to reinstall the firmware and remove the settings ("nvram erase").
Useful tips I wish I had found online:
Good luck!
I meant "GND", not "GNG"
Wow your tips is working on my Netgear EX6200
I succesfully finished this tutorial for my bricked R7000 only to find that I can only boot the router with the USB-TTL cable attached and connected to my PC. I've tried dd-wrt, tomato and even netgear's firmware.
With the cable detached the power led stays red (not flashing) and never proceeds.
When booting with the cable attached I saw that the WAN Modem device was set to /dev/ttyUSB0 which seemed odd. However, I cannot change this value.
Has anybody seen this before?
Hi guys! I'm stuck with my R7000 and it turns out that when I'm in the CFE and I try to access TFTPD, he says: CFE> tftpd Invalid command: "tftpd" Available commands: nvram, reboot, flash, batch, go, boot, load, save, ping, arp, ifconfig, show, help *** command status = -1 and all this I do because it does not let me update medienate web because it tells me that the firmware file is invalid. I ran before: Xwrt Vortex.
i have bricked my R7000. It seems to be alive (some short ping responses soon after power up), but i do not get any output on the serial port. In addition it behaves like WiKing's in regards to the "GND". I also tried the tftp method suggested by Netgear without an succsess.
Hope some out here might have any additional input?
I have R7000P that I am trying to fix using minicom for OSX. I am not sure which pins to connect my USB serial cable to. I have done some extensive searches to no avail. There are 4 pins on the board, similar to the R7000, but I am getting no response when I follow the above instructions. I have tried swapping the TX RX wires and that doesn't work either.
So, I got the pin config sorted out, and am able to get to the CFE prompt. Now when I run tftpd, it tries to start the server, but never finishes.
Try this... worked for me:
https://forum.dd-wrt.com/phpBB2/viewtopic.php?p=1135950&sid=fbef6f2fa9c1...
This is not correct for this R7000P, which tested out as
[RxD] [TxD] [GND] [3.3]
as viewed from the front of the router
I was trying to debirck my R7000P and couln't get any output from the console. Finally found this article that explains that the pinout on the R7000P connecter is backwards from the R7000 (viewed from the front):
I have a problem I wanted to know if anyone else has had. I bricked my R700P after DL DD_WRT. I was do a flash when my power was interrupted. Instant brick. NOW It is running in a boot loop. Is it worth fooling with? I just got a Serial Cbale for a Raspberry Pi & have been messing with it all afternoon with no success at all. Any suggestions or words of wisdom ????
Thx
Netgear EX6200
Pin 2 = GND
Pin 3 = RXD
Pin 4 = TXD
I successfully reinstall the official firmware after bricked with DD-WRT firmware
*After follow this tutural and follow WiKing tips https://www.myopenrouter.com/comment/41385#comment-41385
My ROUTER IP is assign to 192.168.1.250, not 192.168.1.1
#PuTTY log#
Device eth0: hwaddr 6C-B0-CE-00-00-00, ipaddr 192.168.1.250, mask 255.255.255.0
Startup canceled
CFE> tftpd
Start TFTP server
Reading ::
#WINDOWS CMD#
C:\>tftp -i 192.168.1.250 put EX6200-V1.0.3.90_1.1.125.chk
Transfer successful: 7036986 bytes in 13 second(s), 541306 bytes/s
DONE!!
Thanks ALL
I have the same problem. But I can´t send "Ctrl C" command. How did you do it?
Thank you!
R7000 AC1900 Netgear Nighthawk -Bricked
Upgraded fw to latest from Netgear site. Changed Router to use as a WAP on an existing Wifi Network. This worked for a few days. Then I tried to change the network that the router should access (different SSID). At some point, I had to do a factory reset (hold reset for many seconds until power light flashes). While this did work in the past, this last time, the router never recovered. When I power it on, the lights go through what appears to be a boot sequence then settle with a steady orange power LED and a flashing activity LED on the ethernet port that my PC is connected to.
On the PC i cannot obtain an IP address from the router (DHCP) if i set a manual IP address of 192.168.1.106 then i show no connectivity but in windows network connections, the ethernet connection does show (know) that it is a "NETGEAR09" so it seems like the connection is getting some limited information from the router.
I have connected to the onboard serial pins of the router mainboard according to this article. I can establish some limited communication to the serial port. THE PROBLEM IS THIS: I only see garbage characters in the terminal window. Here is a portion of the Putty Terminal window :
5▒▒Y=▒w59▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒Y_^뺺▒5▒!3▒▒▒YW}▒9!##5957▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒[▒Q▒4▒▒▒W-%5▒7=5▒-%5▒▒Y#▒e=▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒=%55▒U5▒753='▒▒빹▒▒%=-#▒▒▒▒▒Y5▒c!'▒_!5▒▒R▒▒▒{▒▒▒▒▒▒▒E▒m#--='-5▒9!##▒=;'5▒▒▒▒▒▒5#▒▒K▒T
▒/=▒#=%5▒3!#7▒▒K▒T ▒Z▒
▒/=▒#=%5▒3!#7▒▒K▒T▒Z▒;9!▒)!▒▒#!▒%!7'5▒;
▒/=▒#=%5▒3!#7▒▒M▒)▒▒9%7▒▒▒▒▒c!▒9/▒75-95▒▒'▒▒#!▒▒-#▒▒▒59▒▒^▒S▒-#1▒75-95▒#!75▒▒▒▒[▒T▒▒mw_▒5#1-#5▒▒▒▒▒▒▒j▒▒▒'5▒=15#▒!▒5▒-1#=▒3-'5▒▒%▒#7▒▒▒▒▒▒▒I%=-#▒▒▒▒▒E▒▒)=Y=▒▒▒9955757▒▒I%=-#▒▒▒▒▒E▒▒Y-1#=▒5▒%=+!▒▒▒▒▒%-#!▒▒▒▒▒▒▒I%=-#▒▒▒▒▒E▒▒u#=;'5▒m_Y▒▒▒I%-#▒▒▒▒▒E▒▒m_Y▒5#=;'5▒▒▒▒▒▒I%=-#▒▒▒▒▒E▒▒m_Y▒▒▒▒▒▒▒▒▒RIOK▒-▒▒▒+-▒)=Y/w!#▒▒▒▒m#5Uw▒▒▒▒▒▒[▒T▒▒3!▒%!7'5▒▒%▒#7▒7A7;3▒)!▒-/▒=%▒▒▒75A=#▒5/▒▒▒▒▒▒U▒R▒▒A%!7▒▒▒▒▒U▒R▒▒7;A!7▒▒▒▒▒U▒R▒▒k▒▒A%!7▒▒▒▒▒▒SR▒5▒75-95▒#!75▒▒▒▒▒▒▒▒▒5!▒
-continuing....
No amount of ^c ^c ^c will stop this. I CANNOT access the CFE command. I can not read any legible words in the window.
I have tried a Win10 PC, Win 7 PC, and 2 different "known working" USB to serial adapters. One for sure is FTDI.
Trying to "put" the Netgear firmware .CHK file onto the router via command promtp and tftp command, I just get "connect request failed".
I suspect that even my CFE file is corrupted. Where do i obtain the CFE file and how is it installed?
Any other advice is apreciated.
Kurtman.
-continuing....
Trying to "put" the Netgear firmware .CHK file onto the router via command prompt and tftp command, I just get "connect request failed".
Any other advice is apreciated that will further direct me to "un-brick" this beauty.
Kurtman.
Hello! I had an R7000 working slow and I've powered it off then on. It wont boot anymore (Only getting dim orange power LED and no ping response). Tried the above method with linux and minicom and when i try to boot the only message that appears is "digital core power voltage set to 1.0v" nothing else...
Is it bricked? I have no more ideas... Thanks guys!
Hello All, I am having an issue with my R7000 I have set up my USB to TTL adapter in win10 and its working (tested connecting to a raspberry pi and I can send and recived with out isssues in putty)
But when I try to connect to my R7000 putty stays blank. I have already reversed the RX and TX pins but no change.
Could it be that its bricked to the point that there wont be a serial signal comming from the router pins?
When I press Ctrl+C, the boot process didn't stop at the CFE> prompt.
06 --+++++++++++++++++++++++X++++++++++++++++++++++----------------
07 -------++++++++++++++++++++++++++X+++++++++++++++++++++++++-----
08 ---------++++++++++++++++++++++X++++++++++++++++++++++----------
09 --------------+++++++++++++++++++++++X++++++++++++++++++++++----
10 ----------+++++++++++++++++++++++X++++++++++++++++++++++--------
11 ----------------++++++++++++++++++++++++X++++++++++++++++++++++-
12 -------+++++++++++++++++++++++X+++++++++++++++++++++++----------
13 --------------++++++++++++++++++++++X++++++++++++++++++++++-----
14 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
15 -------------++++++++++++++++++++++++X+++++++++++++++++++++++---
PW0
0000000000111111111122222222223333333333444444444455555555556666
0123456789012345678901234567890123456789012345678901234567890123
00 ----+++++++++++++++++++++++++++X++++++++++++++++++++++++++------
01 ---------+++++++++++++++++++++++++X++++++++++++++++++++++++-----
02 ------++++++++++++++++++++++++++X+++++++++++++++++++++++++------
03 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
04 -++++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
05 ----++++++++++++++++++++++++++X++++++++++++++++++++++++++-------
06 +++++++++++++++++++++++++X+++++++++++++++++++++++++-------------
07 ------+++++++++++++++++++++++++++X+++++++++++++++++++++++++++---
08 ----++++++++++++++++++++++++X++++++++++++++++++++++++-----------
09 ----------++++++++++++++++++++++++X++++++++++++++++++++++++-----
10 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
11 -----------++++++++++++++++++++++++++X+++++++++++++++++++++++++-
12 ---+++++++++++++++++++++++++X+++++++++++++++++++++++++----------
13 -----------++++++++++++++++++++++++X+++++++++++++++++++++++-----
14 -----++++++++++++++++++++++++++X+++++++++++++++++++++++++-------
15 ----------+++++++++++++++++++++++++X+++++++++++++++++++++++++---
NW0
00 ----+++++++++++++++++++++++++X+++++++++++++++++++++++++---------
01 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
02 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
03 -----+++++++++++++++++++++++X+++++++++++++++++++++++------------
04 --+++++++++++++++++++++++++X++++++++++++++++++++++++------------
05 ----++++++++++++++++++++++++++X+++++++++++++++++++++++++--------
06 -+++++++++++++++++++++++X+++++++++++++++++++++++----------------
08 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
09 --------------+++++++++++++++++++++++++X++++++++++++++++++++++--
10 ----------++++++++++++++++++++++++X+++++++++++++++++++++++------
11 ----------------++++++++++++++++++++++++X+++++++++++++++++++++++
12 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
13 --------------+++++++++++++++++++++++X+++++++++++++++++++++++---
14 ---------+++++++++++++++++++++++++X+++++++++++++++++++++++++----
15 -------------+++++++++++++++++++++++++X++++++++++++++++++++++++-
WRDQW0
00 ++++++++++++++++++++++X++++++++++++++++++++++-------+++++++++++-
01 ++++++++++++++++++++++++X+++++++++++++++++++++++-------++++++++-
02 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
03 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
04 +++++++++++++++++++++X++++++++++++++++++++-----------++++++++++-
05 ++++++++++++++++++++++++X+++++++++++++++++++++++-----++++++++++-
06 ++++++++++++++++++++X++++++++++++++++++++------------++++++++++-
07 ++++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++-
08 ++++++++++++++++++++++X++++++++++++++++++++++--------++++++++++-
09 ++++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
10 +++++++++++++++++++++++X+++++++++++++++++++++++--------++++++++-
11 -+++++++++++++++++++++++X+++++++++++++++++++++++-----------++++-
12 +++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++-
13 -+++++++++++++++++++++++X+++++++++++++++++++++++---------++++++-
14 ++++++++++++++++++++++++X+++++++++++++++++++++++------+++++++++-
15 -+++++++++++++++++++++++X++++++++++++++++++++++-----------+++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR
00 ++++++++++++++++++S++++++++++++X++++++++++++++++++++++++++++++++
Decompressing...done
CFE for Foxconn Router R7000 version: v1.0.22
Build Date: Wed Mar 19 11:14:20 CST 2014
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcodet0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
et1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0: hwaddr 00-3B-D2-6C-1C-DB, ipaddr 192.168.1.1, mask 255.255.255.0
load default!
Digital core power voltage set to 1.0V
SHMOO VER 1.13
PKID07DC06011801080000000000001A103F01000000
S300001C7
000012B0
RDLYW0 00000004
RDENW0 00000031
RDQSW0
01 ----------++++++++++++++++++++++++X+++++++++++++++++++++++------
08 --------++++++++++++++++++++++X++++++++++++++++++++++-----------
09 --------------++++++++++++++++++++++X++++++++++++++++++++++-----
11 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-
14 ---------++++++++++++++++++++++++X+++++++++++++++++++++++-------
PW0
01 ---------+++++++++++++++++++++++++X+++++++++++++++++++++++++----
02 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
04 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
06 -+++++++++++++++++++++++++X++++++++++++++++++++++++-------------
07 -------+++++++++++++++++++++++++++X++++++++++++++++++++++++++---
08 -----++++++++++++++++++++++++X+++++++++++++++++++++++-----------
10 -------++++++++++++++++++++++++X++++++++++++++++++++++++--------
11 ------------++++++++++++++++++++++++++X++++++++++++++++++++++++-
12 ----+++++++++++++++++++++++++X++++++++++++++++++++++++----------
13 ------------+++++++++++++++++++++++X+++++++++++++++++++++++-----
14 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
15 ---------++++++++++++++++++++++++++X+++++++++++++++++++++++++---
NW0
04 ---++++++++++++++++++++++++X++++++++++++++++++++++++------------
08 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
09 --------------+++++++++++++++++++++++X+++++++++++++++++++++++---
10 ---------++++++++++++++++++++++++X++++++++++++++++++++++++------
11 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++
14 ---------+++++++++++++++++++++++++X++++++++++++++++++++++++-----
15 --------------+++++++++++++++++++++++++X+++++++++++++++++++++++-
WRDQW0
05 +++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++-
06 +++++++++++++++++++++X++++++++++++++++++++-----------++++++++++-
08 ++++++++++++++++++++++X+++++++++++++++++++++---------++++++++++-
09 ++++++++++++++++++++++++X+++++++++++++++++++++++--------+++++++-
10 +++++++++++++++++++++++X++++++++++++++++++++++--------+++++++++-
11 -+++++++++++++++++++++++X++++++++++++++++++++++-----------+++++-
12 +++++++++++++++++++++++X++++++++++++++++++++++------+++++++++++-
13 -+++++++++++++++++++++++X+++++++++++++++++++++++----------+++++-
14 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
15 -+++++++++++++++++++++++X++++++++++++++++++++++----------++++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR
Init Arena
Init Devs.
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
load default!
SHMOO VER 1.13
S300001C3
000012A0
RDLYW0 00000004
RDENW0 00000031
RDQSW0
00 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------
01 -----------++++++++++++++++++++++++X+++++++++++++++++++++++-----
02 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
03 -------+++++++++++++++++++++++X+++++++++++++++++++++++----------
04 -----++++++++++++++++++++++++X++++++++++++++++++++++++----------
05 -------+++++++++++++++++++++++++X++++++++++++++++++++++++-------
06 ---+++++++++++++++++++++++X+++++++++++++++++++++++--------------
07 ---------++++++++++++++++++++++++++X+++++++++++++++++++++++++---
08 ----------+++++++++++++++++++++++X++++++++++++++++++++++--------
09 ----------------++++++++++++++++++++++++X+++++++++++++++++++++--
10 -----------+++++++++++++++++++++++X+++++++++++++++++++++++------
11 -----------------+++++++++++++++++++++++X+++++++++++++++++++++++
12 ---------+++++++++++++++++++++++X+++++++++++++++++++++++--------
13 ----------------++++++++++++++++++++++X++++++++++++++++++++++---
14 ----------+++++++++++++++++++++++++X++++++++++++++++++++++++----
15 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-
PW0
00 ------+++++++++++++++++++++++++++X++++++++++++++++++++++++++----
01 ------------++++++++++++++++++++++++X++++++++++++++++++++++++---
02 ---------+++++++++++++++++++++++++X++++++++++++++++++++++++-----
03 ------+-+++++++++++++++++++++++++X++++++++++++++++++++++++------
04 -----+++++++++++++++++++++++++X++++++++++++++++++++++++---------
05 ------++++++++++++++++++++++++++X++++++++++++++++++++++++++-----
06 --+++++++++++++++++++++++++X+++++++++++++++++++++++++-----------
07 ---------+++++++++++++++++++++++++++X+++++++++++++++++++++++++--
08 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------
09 -------------+++++++++++++++++++++++++X+++++++++++++++++++++++--
10 --------+++++++++++++++++++++++++X++++++++++++++++++++++++------
11 --------------+++++++++++++++++++++++++X++++++++++++++++++++++++
12 ------+++++++++++++++++++++++++X++++++++++++++++++++++++--------
14 --------++++++++++++++++++++++++++X+++++++++++++++++++++++++----
15 ------------++++++++++++++++++++++++++X++++++++++++++++++++++++-
NW0
00 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
04 ----++++++++++++++++++++++++X++++++++++++++++++++++++-----------
05 ------+++++++++++++++++++++++++X+++++++++++++++++++++++++-------
06 ---+++++++++++++++++++++++X++++++++++++++++++++++---------------
08 ----------++++++++++++++++++++++++X++++++++++++++++++++++++-----
09 ---------------++++++++++++++++++++++++X+++++++++++++++++++++++-
10 -----------++++++++++++++++++++++++X++++++++++++++++++++++++----
11 ------------------+++++++++++++++++++++++X++++++++++++++++++++++
12 ---------++++++++++++++++++++++++X+++++++++++++++++++++++-------
13 ---------------++++++++++++++++++++++++X++++++++++++++++++++++--
14 -----------+++++++++++++++++++++++++X++++++++++++++++++++++++---
15 ---------------++++++++++++++++++++++++X++++++++++++++++++++++++
WRDQW0
00 ++++++++++++++++++++++X+++++++++++++++++++++-------++++++++++++-
01 ++++++++++++++++++++++++X++++++++++++++++++++++++------++++++++-
02 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
05 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
07 +++++++++++++++++++++++X+++++++++++++++++++++++------++++++++++-
10 +++++++++++++++++++++++X+++++++++++++++++++++++-------+++++++++-
13 -+++++++++++++++++++++++X++++++++++++++++++++++----------++++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
Init Arena
Init Devs.
DDR Clock: 800 MHz
load default!
SHMOO VER 1.13
S300001C3
000012A0
RDLYW0 00000004
RDENW0 00000031
RDQSW0
05 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
07 --------+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
14 --------++++++++++++++++++++++++X++++++++++++++++++++++++-------
PW0
03 -----+++++++++++++++++++++++++X+++++++++++++++++++++++++--------
NW0
00 ---++++++++++++++++++++++++++X+++++++++++++++++++++++++---------
01 ---------++++++++++++++++++++++++X+++++++++++++++++++++++-------
03 ----++++++++++++++++++++++++X+++++++++++++++++++++++------------
07 ------+-+++++++++++++++++++++++++X+++++++++++++++++++++++++-----
12 --------++++++++++++++++++++++++X+++++++++++++++++++++++--------
WRDQW0
03 +++++++++++++++++++++++X+++++++++++++++++++++++-----+++++++++++-
WRDMW0 00000022
WRDMW0 00000023
ADDR
Init Arena
Init Devs.
DDR Clock: 800 MHz
load default!
