2017-10-16 R9000 Kong Build not updating?
6 posts / 0 new
Air
Anyone eles having problems with latest kong build (2017-10-16) not updating? Im Currently running 2017-8-9 and when i try to update to lastest build it just hangs there.
Sorry for double post first one didnt post text idk why
MyOpenRouter Team
Hm, we're running a device
Hm, we're running a device with the 10/16 build here with no issues (we did update from the latest build before that)
Have you tried performing a reset in DD-WRT, then attempting the upgrade? That might do the trick.
If all else fails, you can return the R9000 to stock NETGEAR firmware, then flash the .CHK file from Kong (not the BIN, those are just for DD-WRT -> DD-WRT upgrades) which should work.
Air
Air
I think the file for the 2017-10-16 here is corrupted because i downloaded it from somewhere eles and it updated without issues
Ugg why dose this site post my stuff with no text.
Attila
I installed DD-WRT Kong Mod for NETGEAR R9000 (2017-10-16 img), Wrong Firmware !!!
dd-wrt-netgear-R9000_BIN_20171016.zip does not work
I can not restore the original R9000 firmware.
ask for help!
Thanks!!
Attila
Helló, telepítettem a DD-WRT
Helló,
telepítettem a DD-WRT Kong Modot a NETGEAR R9000 (2017-10-16 img), a rossz firmware-hez !!!
dd-wrt-netgear-R9000_BIN_20171016.zip nem működik
Nem tudom visszaállítani az eredeti R9000 firmware-t.
kérjen segítséget!
Kösz!!
