Bricked R7000 after applying initial tomato firmware
3 posts / 0 new
darkjoy
I just got a new Netgear R7000 and bricked it right away.
I did uplad the initial package [tomato-R7000-initial.chk] and after that the router become unresponsive.
I tried all of the suggested methods (including the Shibby's [updated] notes), apart of getting a usb to ttl cable.
Having a firmware available that actually bricked so many routers is a shameful thing. I'm so pissed of that I didn't read all of the complains before I followed the video instruction. angry
Thanks for any help
Codypfeil417
Yes this just happened to me
Yes this just happened to me as well. Just a blinking white light.
Lomtevas
The unbricking fix is tricky
The unbricking fix is tricky and takes some trial and error, but the router can be reprogrammed.
You have to download the TFTP client and the proper netgear firmware. Connect your router by LAN cable to a stand-alone computer like a PC or Mac. The IP address of the router will be 192.168.11.1 and the computer's will be 192.168.11.2. Launching TFTP and loading the firmware is then followed by hitting the 'go' button. If it errors out, try a different computer IP incrementing by 1. This should load the firmware and restart the router as fully operational. Then reinstall DD-WRT or whatever other firmware you prefer.
Also, never mismatch the firmware to the router. Any difference in router type will brick the router. Then you'll have to TFTP again and again.
