Hi All,
I tried upgrading to Build 23770 R01 OLD tonight, but had major issues after upgrading from 23770 NEW. I then did a factory reset, and everything worked great -- I did get faster speeds 23770.
I then started adding my settings back in, and after adding in 18 static leases, and applying the settings, the issues started again. The speed is extremely slow, and most of my devices cannot grab an IP. This happens with wired and wireless.
I then reverted back to 23770 NEW, added my settings back in performing the same steps, and everything worked perfectly again.
Anyone noticing similar bahavior?
