Hi guys!
I just switch firmware from dd-wrt to Tomato because of a software issue I wasn't able to fix on the DD-WRT.
Now this particular issue is solved with the Tomato firmware!
Only thing is that I want to run a startup script that I was running on DD-WRT, but the script won't seem to work with Tomato and I have no idea how to convert it!
Here is the script, if anyone can help me convert it, it will be so much appreciated!
/usr/sbin/ip addr add 24.37.249.84/29 dev vlan1 /usr/sbin/iptables -t nat -I POSTROUTING 1 -p all -s 192.168.1.152-j SNAT --to 24.37.249.84 /usr/sbin/iptables -t nat -A PREROUTING -p tcp -d 24.37.249.84 --dport 80 -j DNAT --to-destination 192.168.1.152 /usr/sbin/iptables -I FORWARD -p tcp -d 192.168.1.152 --dport 80 -j ACCEPT
I think the error may be caused by the SNAT part, but I'm really not sure!
Thank you so much for any help!
Have nice day
The code wasn't clear and I didn't found where to edit my post :
