Data management , how tomato store data in the flashmemory for WNR3500L
2 posts / 0 new
oOIssaMOo
hi evrevyone ,
 can someone explain how data are stored in flash memory by abording theses points :
the root directory of tomato is mounted with squashfs , but there is a /tmp directory wich is mouted with tmpfs . In that directory user temporaly files are stored before to be saved on flash memory  (if that process is wrong please correct it) .
  • So when the data are stored in flash memory ? At bootup ,shutdownd , running ..
  • How data are stored in flash memory ?
LitlJay
You may do better to direct
You may do better to direct your question to some real dirt-under-the-nails linux guys. Try the forums at linuxquestions.org
