DD-WRT v24-sp1 compilation issue
15 posts / 0 new
achilles
Hi all ,
I want to compile DD-WRT v24-sp1 but I am not able to do this and I am getting following error message while trying to
do so .....
 /DD-WRT/toolchains/3.4.6-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/3.4.6/../../../../mipsel-linux-uclibc/bin/ld: iptables: hidden symbol `__udivdi3' in /DD-WRT/toolchains/3.4.6-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/3.4.6/libgcc.a(_udivdi3.oS) is referenced by DSO
/DD-WRT/toolchains/3.4.6-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/3.4.6/../../../../mipsel-linux-uclibc/bin/ld: final link failed: Nonrepresentable section on output
Could any one plz tell me what can be the reason behind this and how to overcome it ????
thanks in advance ,
achilles
Tathagata Das said:
Tathagata Das said:
It is most probably toolchain issue. Somewhere your cross compiler may be corrupter or you might be using wrong cross compiler. Can you please download the fresh toolchain and try it again ?
thnx for the suggestion ... now I am able to compile it though with a different tool chain ... previously I was using 3.4.6-uclibc-0.9.28 but now I am using 4.1.0-uclibc-0.9.28 and compilation is through ... :)
John Lauro
I am trying to compile all
I am trying to compile all from source, and having a similar issue. You mention you were using:
3.4.6-uclibc-0.9.28 and now using:
3.4.6-uclibc-0.9.28
I am not sure I understand the difference.
It does appear to want a different (or at least different location) for the tool chain.
I followed the direction at (and brought in the full 20gb kernel source for all versions): http://www.dd-wrt.com/wiki/index.php/Development
achilles
3.4.6-uclibc-0.9.28
Sorry john, In my last post I mentioned the same tool chain twice by mistake .... actually the tool chain version that you need to get compilation through is :
4.1.0-uclibc-0.9.28
Use this and u will be able to compile the DD-WRT distribution .....
John Lauro
achilles said:
achilles said:
John Lauro said: I am trying to compile all from source, and having a similar issue. You mention you were using: 3.4.6-uclibc-0.9.28 and now using: 3.4.6-uclibc-0.9.28 I am not sure I understand the difference. It does appear to want a different (or at least different location) for the tool chain. I followed the direction at (and brought in the full 20gb kernel source for all versions): http://www.dd-wrt.com/wiki/index.php/Development
4.1.0-uclibc-0.9.28
Ok, that makes sense when I get to that point.  Right now I am having problems just running the prep scripts.  I started fixing some non portable code in jsformat and build for squashfs, but decided I rather work on the main router code instead of the build environment, or I may run into problems later on that I don't notice as it appears to be tied to specific distro...  I tried both 64-bit and 32-bit Centos 5, but it appears that Debian is what I should have used, as apparently Debian has some gcc patches that makes it behave differently.  Should I use the 32-bit distro or a 64-bit AMD distro, or better yet, what ISO should I reinstall from that will give me the least issues building?
achilles
Yep , there are some problems
Yep , there are some problems in running prep scripts due to 32-bit and 64-bit environment issues .... I would suggest u to use the 32-bit distro ...
BTW I have prepared few scripts to automate download and build of DD-WRT for WGR614L ... I have tested them on FC6 and will post them very soon ...
you can use those scripts or at least take some clue from there...
Also I would sugeest u to go through the following link at least once :
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=165514&sid=41cf23dbcd2ffadb...
It has mention and solution of several common DD-WRT compilation issues ...
John Lauro
32-bit FC6? Kind of old (10
32-bit FC6? Kind of old (10 is current), but found an archive that has it. Downloading as I type this... so I will be ready for when you post the build scripts. :) Thank you.
achilles
John Lauro said: 32-bit FC6?
John Lauro said: 32-bit FC6? Kind of old (10 is current), but found an archive that has it. Downloading as I type this... so I will be ready for when you post the build scripts. :) Thank you.
ya it z old but I did not feel the need of changing it for the time being ..... BTW i have posted my scripts but currently it z in the review queue ....
BTW if u r done with the download I can suggest u the steps that need to proceed ....
Just copy the following stuff in a shell script in xxxx/yyyy/DD-WRT/opt and run it ....
cd ../src/router
make clean
make
make install
cd -
./sstrip/sstrip ../src/router/mipsel-uclibc/target/bin/*
./sstrip/sstrip ../src/router/mipsel-uclibc/target/sbin/rc
./sstrip/sstrip ../src/router/mipsel-uclibc/target/usr/sbin/*
cp ./bin/ipkg ../src/router/mipsel-uclibc/target/bin
cp ./libgcc/* ../src/router/mipsel-uclibc/target/lib
cd ../src/router/mipsel-uclibc/target/lib
ln -s libgcc_s.so.1 libgcc_s.so
cd -
cp ./etc/preinit ../src/router/mipsel-uclibc/target/etc
cp ./etc/postinit ../src/router/mipsel-uclibc/target/etc
cp ./etc/ipkg.conf ../src/router/mipsel-uclibc/target/etc
cp ./etc/config/* ../src/router/mipsel-uclibc/target/etc/config
cp ./usr/lib/smb.conf ../src/router/mipsel-uclibc/target/usr/lib
cd ../src/router/mipsel-uclibc/target/www
ln -s ../tmp/smbshare smb
cd -
../src/linux/brcm/linux.v24_2/scripts/squashfs/mksquashfs-lzma ../src/router/mipsel-uclibc/target target.squashfs -noappend -root-owned -le
echo "<------- Creating TRX image -------->"
./tools/trx_wgr614 -o linux.trx ./loader-0.02/loader+400.lzma ../src/router/mipsel-uclibc/vmlinuz -a 1024 target.squashfs
echo "<-------- Creating CHK image ---------->"
touch emptyfile
echo U12H072T00_NETGEAR >> compatible.txt
./tools/packet -k linux.trx -f emptyfile -b compatible.txt -ok kernel_image -oall dd-wrt -or rootfs_image -i emptyfile
rm -f emptyfile compatible.txt kernel_image.chk rootfs_image.chk
I hope this will help u out .......
imran
@achilles
@achilles
I have also gone through the hardship that is required to compile the DD-WRT distribution .... though I am able to get it compiled but I am looking forward to get your scripts from this site and test them for my build ....
When will your scripts be available .... Will it be a beta release ?... Will there be any instructions to use them and have you tested them on anything other that FC6 ....
thnx
achilles
imran said:
imran said:
@achilles
thnx
It will be available very soon and it will be a beta release ..... All suggestions/feedback for improvement of these scripts are welcome .... There will instructions to utilize these scripts ..... Besides FC6 I have tested it on FC9 ....
John Lauro
It took a long time to get
It took a long time to get FC6 downloaded and installed... download rate was about 1/10th of what I was used to.
The good news, switching to FC6 helped in that I was able to get further without having to modify the C code or makefiles. However, still running into some problems well before it compiles everything.
It does go further, but unfortunately, I have not been able to compile it all. Should I run the script you run prior to, after, or instead of the scripts mention on dd-wrt ( 0. Run ready_ddwrt.sh and ready_ddwrt_root.sh, and in DD-WRT/opt run ./install.sh. Running ./install_* to build a particular variant requires you rebuild shared code first.)? The make command did prompt for several configuration options.
The error I am receiving:
In file included from /home/ddwrt/DD-WRT/src/router/shared/wlutils.h:19,
from utils.c:25:
/home/ddwrt/DD-WRT/src/include.v23/wlioctl.h:24:28: error: proto/bcmevent.h: No such file or directory
That file is in include.v24, but not include.v23. I am tempted to just copy it and see.
John Lauro
I see your scripts were
I see your scripts were posted, and after some reworking of the tool chains I was able to get them to work, but have not tried to upload it to a router yet...
A pointer as to which version(s) of the toolchains you have installed and thus are known to work would be a helpful addition to your documentation or scripts.
I do have cables on order and want to put that mod in place first in case I brick it...
achilles
The toolchain version that I am using in my builds is :
4.1.0-uclibc-0.9.28
Keep us posted about your findings once you flash your router with this image ...
John Lauro
achilles said:
achilles said:
John Lauro said: I see your scripts were posted, and after some reworking of the tool chains I was able to get them to work, but have not tried to upload it to a router yet... A pointer as to which version(s) of the toolchains you have installed and thus are known to work would be a helpful addition to your documentation or scripts. I do have cables on order and want to put that mod in place first in case I brick it...
4.1.0-uclibc-0.9.28
Sorry for the delay in getting back on this...  It flashed just fine and is working!  Made some minor mods (just to verify I can reproduce), and reflashed and all is well.  (Actually had trouble the second time getting it to twork with a .trx file and messed it up, but was able to push a .chk via tftp).  Would be nice if dd-wrt support .chk files directly, or if the build process also made a .bin that could be used once it's in dd-wrt mode.
achilles
John Lauro said:
John Lauro said:
The toolchain version that I am using in my builds is : 4.1.0-uclibc-0.9.28  Keep us posted about your findings once you flash your router with this image ...
Hi John,
Thanx for update from ur side ... I will definitely look into your suggestion and try to write some scripts that will create a bin image which can be flashed into WGR614L ....
