I'm wondering if I could set the video/audio file library to a path on one of the computers connected, through LAN sharing or something? Or do I have to attach a USB drive to the router?
I'm a newbie. If this is too simple and naive, forgive me.
In 'theory' you could do it by using a small thumb drive.
You could plug it into the router then set it up for MiniDLNA. Creating the database on the thumb drive.
Then by using something like mount.cifs http://www.samba.org/samba/docs/man/manpages-3/mount.cifs.8.html to get it to mount your computer shares.
You probably would have to do some 'experimenting' to see if you could get it working.
I've not figured out the relations between the thumb drive and CIFS.
If I could get a network share mounted using CIFS, that doesn't mean I could directly specify the mounted path as the library path and create the database there? So why use the thumb drive?
But what would be the point? You may as well run the server on the PC.
So that is supported?
I wanna do that because I wanna cut the trouble of installing a DLNA server. I tried windows media player 12, and I'm not quite into it.
