E4200 Advice
1 post / 0 new
skyking_comms
E4200 Advice
​Today I purchasd a E4200 v1 which has 'Tomato Firmware v1.28.04.99 MIPSR2Toastman-RT-N K26 USB Ext' installed.
I'd like to use the router for -
  • UnoTelly (I can only see DD-WRT instructions on their website)
  • Connect a USB HDD
  • Connect to both 2.4 and 5 ghz channels
Reading some of the forums some of the firmwares dont have USB support whilst others dont have 5ghz.
I already have a E1200 running DD-WRT but wanted this E4200 for the USB and 5 ghz.
So should should I stick with the Tomato version already installed, install a better Tomato version or install DD-WRT?
Appreciate any advice
