Help, forgot password for TomatoUSB (Shibby) and backdoor not working.
1 post / 0 new
Jackfrost6022
Hey all,
  I've found myself somewhat in this predicament. I forgot my password on a Netgear Nighthawk R7000 router
after installing Shibby's tomatousb on it. I attempted to reset but apparently that's an endeavor in vain. I then read Shibby's instructions
to use the backdoor.
Do this:
1) run router and wait 2-3
5) use result as password
However, I ran into an issue. I get the router up and booted (step 1) and then
hold the wifi button as required (step 2). During this time the button
flashes while I hold it and goes off when I finish. I then attempt to
login on port 233. Everything hangs. I tried logging in without a user,
logging in as root and admin. I just wait indefinitely. Is there
something I'm doing wrong?
Help Shibby, your my only hope! (/joke)
