I have Port Frowarded The Port 36566 For My mine craft Server IT worked Good for about a mounth Then Ranomly no one out Side of the Lan can connect Yes i Made Sure my internal / external IP didnt Change
Website security can be a complex and even confusing topic because of its ever-evolving landscape, for that reason, it’s important to keep in mind that security (especially website security) is never a set-it-and-forget-it solution.
HELP PLZ!
Which router and which firmware are you using ??
