HOW-TO get addtional flash space on the WGR614 by trimming the code
2 posts / 0 new
Varuna
There could potentially be situations where you might need additional space
on the flash to store the developed application.  Following instructions help
to take a decison on how to get a tiny amount of additional space on the router
flash.
The instructions have been verified on the following setup:
        Netgear WGR614v9 router
        Source code: Netgear WGR614v9-V1.2.6_18.0.17WW
        Tool chain: hnd-tools-3.2.3
        Tools: Telnetenable-0.3
        Development system: Fedora 8 kernel 2.6.26
1. Edit .../src/router/busybox/Config.h and comment the following:
        define BB_CP
        define BB_PING
        define BB_FEATURE_FANCY_PING
         define BB_RMDIR
    Note: Prior to modifying the indicated files, please check if the
    services provided by the file are required in your setup.
2. Remove the code between the html tags <script> and </script> from the
    following files in the directory .../project/acos/www/html:
        BKS_keyword.htm
        BKS_service.htm
        DNS_ddns.htm
        FW_forward.htm
        FW_forward_service.htm
        FW_pt.htm
        FW_pt_service.htm
        FW_schedule.htm
        FW_remote.htm
        UPNP_upnp.htm
        WAN_wan.htm
        WIZ_sel.htm
        WLG_wds.htm
        WLG_wireless1.htm
        WLG_wireless2.htm
        WLG_wireless3.htm
    services provided by the trimmed files are required in your setup.
3. Build the router section of the code under ../src/router using the
    following commands:
        make clean
        make
        make install
Trimming of the above web pages and the router.h file yeilds about 80KB of
additional flash space on the router.
Suggestions and comments will be gladly accepted.
Peter Redmer
This is great, thanks for
This is great, thanks for posting. I'd love to hear from community members as to this procedure: was it easy to do, was it effective, etc.
