I am using Kong's dd-wrt build on my 3500L. I noticed that ls command displays color, but I can't seem to find a way to change the color.
I tried setting LS_COLORS via
export LS_COLORS="no=00:fi=00:di=01;31:ln=01;33:pi=40;33:..."
This doesn't work. (dircolors command don't exist so setting it directly).
I tried the alternative of using LSCOLORS, it also didn't work
export LSCOLORS=BxDxFxdxCxdxdxBxBxBxBx
So, can the ls color scheme be modified? I find the default dark blue for directory entry unbearably painful to look at against a black background, and usually one of the above method works for Linux, but not in this case, unless I am missing something obvious...
