Infinity USB Smart on WNR3500L
7 posts / 0 new
schwa226
schwa226's picture
I just want to ask if this card reader will work on the USB port without needing a special driver?
In VCP-Beta 26 it supports Dreambox:
[quote]Modules specific for Linux servers:
Smart VCP BetaID=25
Smart VCP BetaID=25CC
Module specific for DreamBox and other STB's:
Smart VCP BetaID=26[/quote]
http://www.infinityusb.com/default.asp?show=productsdetail&ProductID=12
Will it also be mounted at /mnt?
schwa226
schwa226's picture
Ok,
Ok,
I just tested the reader and it is not found:
BusyBox v1.13.4 (2010-04-23 03:15:38 CEST) built-in shell (ash)
root@HomeServer:~# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
none on /dev type devfs (rw)
proc on /proc type proc (rw)
ramfs on /tmp type ramfs (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
devpts on /proc/bus/usb type usbfs (rw)
/dev/discs/disc0/disc on /mnt type vfat (rw,fmask=0022,dmask=0022,codepage=cp437
,iocharset=iso8859-1)
root@HomeServer:~#
It is the reader and a USB flash drive connected but only the flash get listed. If I connect two flash drives there are also listed.
Any help how to get this reader up and running?
schwa226
schwa226's picture
Got it now running:
Got it now running:
disabled USB 2.0 support and added this for startup:
insmod usbserial.o
insmod ftdi_sio.o
The Reader is working now!
May there is a solution to use the reader also when USB 2.0 is enabled?
The error:
drivers/usb/serial/ftdi_sio.c: ftdi_tiocmget Could not get modem status of device - err: -32
BiG
BiG's picture
How do you access the card
How do you access the card reader once it's working?
After I do the insmod's the following is displayed through dmesg:
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usb 1-1: new full speed USB device using ohci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
usbcore: registered new interface driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver ftdi_sio
drivers/usb/serial/ftdi_sio.c: v1.4.3:USB FTDI Serial Converters Driver
But I was expecting a new device like /dev/ttyUSB0 or something...
BiG
BiG's picture
This is what I get when
This is what I get when plugging the card reader into my Ubuntu-box:
[282174.916043] usb 3-3: new full speed USB device using ohci_hcd and address 3
[282175.131835] usb 3-3: configuration #1 chosen from 1 choice
[282175.147983] generic-usb 0003:104F:0006.0003: hiddev96,hidraw2: USB HID v1.11 Device [WB Electronics Infinity USB Smart] on usb-0000:00:04.0-3/input0
... how could I get access to the cardreader on the WNR3500L?
schwa226
schwa226's picture
I use: /dev/usb/tts/0
I use:
/dev/usb/tts/0
BiG
BiG's picture
The problem was that I never
The problem was that I never got any device at all...
When I flashed the reader from Windows with the "module" from their webpage it all made sense... The device showed up and all is working very well now!
- Thanks!
