Monitoring broadband for each device using tomato firmware
3 posts / 0 new
Andrew
Can anyone tell me how to monitor each computer and device using tomato firmware.
The router is Linksys WRT54GL and the Tomato Firmware is v1.27.1798.
For example can it tell me how much a voip used or a xbox 360. I would like to get the breakdown for each device.
LJB
Hi Andrew,
Hi Andrew,
I'm new to Tomato myself (running 1.27.9045 BETA11 on a Netgear WNR3500NL) and haven't been able to find this as a "built in" option.
If anyone knows if this is possible, I would be interested as well.
nukie
I think you can do that with
I think you can do that with Gargoyle with your router. I use Gargoyle on my 3 Foneras and its "rock solid".
www.gargoyle-router.com
