need some help or info
3 posts / 0 new
dfjleidsw
Hello guys, i´m new here at the forum.
I use a Netgear WNR3500L quite long and flashed it some years ago with ddwrt.
Now i want to update the firmware, but i am not sure which version is the right one, as i am not really sure which router version i have.  This shows up in the settings:
Firmware: DD-WRT v24-sp2 (11/25/09) std-usb-ftp
System
Router Name WNR3500L
Router-Modell
Netgear WNR3500v2/U/L
Firmware-Version
DD-WRT v24-sp2 (11/25/09) std-usb-ftp - build 13309M NEWD-2 K2.6
i am not sure if this version v2 is correct, because i thought i have an older router.
which firmware is now the right one?
One of these
http://www.myopenrouter.com/download/list?sort=date&cat=48
or one of these?
http://www.myopenrouter.com/download/list?sort=date&cat=74
Thanks for your help!
Subhra
Fisrt identify your router
Fisrt identify your router model and choose firmware for your router accordingly. This article may help you to identify the router model.
haloreach277
try checking on the side of
try checking on the side of the router it should say WNR3500Lv1 or WNR3500Lv2 you can also look at the Netgear box it came in to
