netgear WNR3500L does not work after changing settings
1 post / 0 new
JeEmGu
Hey guys,
The router is running a Tomato software I just bought this used netgear router it worked really fine untill i started messing with the settings. I changed DHCP to off, the wifi settings to channel 13, a password and the IP settings of the router. I had changed the routers IP to 192.168.2.1.
so i tried connection to the router in my browser it didnt work(It still turns on and the lights still flash.) So i pressed the factory reset button this didnt work. i think because it runs tomato software. but when i now enter the gateway it should be on (10.0.0.1) it shows "This webpage is not available" it does show the Tomato icon on the tabs in the top of chrome.
Any help would be highly appreciated also the Router does show ip in the CMD it tells me its on 10.0.0.1
Thanks again (:
