Openvpn-client on Voxel firmware
4 posts / 0 new
vmb
After installing and using Voxels firmware (really quick and stable) on my R7800 I encouterd an issue I can't solve myself.
My problem is that the Openvpn-client won't start. Of course I disabled the server-option in the webgui.
In the logfile (/var/log/openvpn-client.log) the following was registered:
Sun Nov  5 19:39:18 2017 OpenVPN 2.4.4 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Sun Nov  5 19:39:18 2017 library versions: OpenSSL 1.0.2l  25 May 2017, LZO 2.10
Sun Nov  5 19:39:18 2017 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Sun Nov  5 19:39:18 2017 OpenSSL: error:02001002:lib(2):func(1):reason(2)
Sun Nov  5 19:39:18 2017 OpenSSL: error:2006D080:lib(32):func(109):reason(128)
Sun Nov  5 19:39:18 2017 Cannot load CA certificate file ca.rsa.2048.crt (no entries were read)
Sun Nov  5 19:39:18 2017 Exiting due to fatal error
Error: OpenVPN client start failed.
The client directory (/etc/openvpn/config/client) contains 4 files:
ca.rsa.2048.crt
crl.rsa.2048.pem
netherlands.ovpn
pass.txt (with my login credentials)
What can I do to solve this issue? Voxel can you help me? Hope you can ;-), really like your firmware :-)
Voxel
You should use full path to
You should use full path to CA/CRT/KEY files in your netherlands.ovpn. Not just (for example):
ca ca.rsa.2048.crt
but
ca /etc/openvpn/config/client/ca.rsa.2048.crt
etc.
vmb
Thank you Voxel! You made my
Thank you Voxel! You made my day! Everything working fine and up and running...
Voxel
You are welcome ;-) Voxel.
You are welcome ;-)
