OpenVPN Settings Issue (18730)
2 posts / 0 new
b00134n
Changes to "Hash Algorithm" in the OpenVPN client settings seem to not being saving (Kong dd-wrt v18730).  If this setting is changed from SHA256 (default) to SHA1, it will revert to SHA256 upon saving the configuration.
I noticed an unanswered post about this elsewhere on the site and was wondering if anyone might know of a workaround?  The instructions I found for setting up my VPN service use SHA1, so I suspect this bug is preventing things from working.
Thanks in advance!
berndw
I've got the same problem
I've got the same problem with build 19028M after an update from build 18730
I have to set it manually to SHA256 to make OpenVPN work again.
thx
Bernd
