Please help with shared USB drive confusion.
4 posts / 0 new
jolo
I am using Windows 7 with my WNR3500l.
I have had a 1gb external drive connected to my router, using readyshare.
For whatever reason, I do not see it listed as a disk drive any more when I select Computers in Win 7. It used to be there and I gave it a "N" drive designation.
I believe that I have uploaded a screen print of my Advanced USB Storage screen from my router settings.
It can see it via FTP from the settings.
Can anyone help me so that I can see the attached USB drive again from my Win 7 laptop?
JT
Subhra
Try with a different machine,
Try with a different machine, check if the problem persists.
jolo
Thanks for a response. Sadly
Thanks for a response. Sadly,to you are the only one who has responded.
I have uploaded my settings, which I hope helps. It has worked for a few years and suddenly stopped. FTP on it works.
Besides my Windows unit, I have two Android tablets where it is the same thing.
I know the external drive works perfectly as a drive and can be seen using the FTP link as shown on my Netgear configuration screen.
Is there a different way to configure it ??
Subhra
jolo said: Thanks for a
jolo said: Thanks for a response. Sadly,to you are the only one who has responded. I have uploaded my settings, which I hope helps. It has worked for a few years and suddenly stopped. FTP on it works. Besides my Windows unit, I have two Android tablets where it is the same thing. I know the external drive works perfectly as a drive and can be seen using the FTP link as shown on my Netgear configuration screen. Is there a different way to configure it ??
If I haven't misunderstood your words,
  1. You are using same 1gb external drive, and win7 computer with your router.
  2. This setup was working for a few years.
  3. Suddenly, with no change in above setup, things stopped working for you.
If things were in working condition, I didn't found any reason to change the configuration.
I would suggest you to reboot your router and check if scenario changes or not.
