Please help - WNR3500Lv2 with tomato not working
2 posts / 0 new
Roger Ding
Bought a new WNR3500Lv2, flushed Tomato by Shibby for WNR3500Lv2 v111 (All In One).
However, it does not work.
I use a desktop computer, connect to the router, http://192.168.1.1
If connect to Lan1, the ethernet Port state show Wan is connected
If connect to Lan2, the ethernet Port state show Lan4 is connected
If connect to Lan3, the ethernet Port state show Lan3 is connected
If connect to Lan4, the ethernet Port state show Lan2 is connected
If connect to Wan,  http://192.168.1.1 is not accessible.
Then I tried connect cable modem to WAN or Lan1.  My Laptop can see the wireless SSID, but no internet access.
A image file when cable modem connected to WAN (the ethernet Port state show Lan2 is connected) is attached here.
The WAN status always showing Renewing...
Please help, I am new to tomato.  Thank you very much!
RickHansen
Your WAN port is is looking
Your WAN port is is looking for a DHCP Server to give it an IP, so it currently has none. Since the WAN is probably not in the same subnet as the LAN, and since you probably did not configure it for Remote Administration, you can't get to the GUI from the WAN port. Nothing abnormal there.
Shibby's configuration has a checkbox to reverse the LAN hardware port numbering. Check it if it's not checked, uncheck it if it is.
