Hello everybody,
as I can change the transmission settings? When modifying the settings file, located in /jffs/transmission/settings.json and restart the service from Services> NAS> Bittorrent, this is overwritten with the default values, deletes the entered values "incomplete-dir", "/ mnt / sda3 / incomplete "" incomplete-dir-enabled ": true.
Thanks in advance
Hello everybody,
I found the solution. It was very easy. The settings.json file is written when the service is stopped services and is read when is starts, so you have to edit settings.json file when transmission daemon is stopped.
Bye.
