R6250, latest version as well as back to build V3.0R-32170M....
When enabling radio time restrictions, the router ends up having to be rebooted in order order to get any internet working (including WIRED connections)
Not a huge problem, was trying to reduce radiation at night since the router is 6 feet from my head and no-one should be using that one anyway.
Have others seen this problem? I have tried that most recent 3 versions and each is the same - router locks and prevents ALL internet connections when radio scheduling is enabled (even for a 1 hour block) and system does not return to normal. Also at the end of the schedule, wired connections lose internet access.
Scott
