CFE for Foxconn Router R7000 version: v1.0.22
Build Date: Wed Mar 19 11:14:20 CST 2014
Init Arena
Init Devs.
Boot up from NAND flash...
Bootcode Boot partition size = 524288(0x80000)
DDR Clock: 800 MHz
Info: DDR frequency set from clkfreq=1000,*800*
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
et1: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.15.1 (r407936)
CPU type 0x0: 1000MHz
Tot mem: 262144 KBytes
Device eth0: hwaddr E4-F4-C6-00-30-8E, ipaddr 192.168.1.1, mask 255.255.255.0
Checking crc...Loader:raw Filesys:raw Dev:nflash0.os File: Options:(null)
Loading: .. 1452168 bytes read
Entry at 0x00008000
Closing network.
Starting program at 0x00008000
Uncompressing Linux... done, booting the kernel.
I got into CFE but I could do anything. If there was an ethernet port working it would be great. Can you do it in USB ports? Can someone please help?
Well, the output you list shows the router going past CFE and booting Linux. For CFE, it would actually stop about half way through that mess and give you the prompt. Part of the definition of bricked is that the router can't be reached for further comment - on any port. Were you able to start ftpd and get to the "Reading::" prompt? You won't be able to just issue a command to bring up an ethernet port unti the router is de-bricked.That output is from the boot loader, not the router.
spaceX
