R7000 upgrade help
1 post / 0 new
peter-mitel
R7000 upgrade help
Hi guys!
I had sucessful flashed my router 2 months back with tomato firmware.
But there has been an upgrade for a while now and I haven't upgraded
it. There are two files needed for the flashing - .chk and .trx. The
.chk for the initial flash and .trx for the final flash.
Now, for the upgrade to the latest firmware do I need both files to do it? Is the initial .chk file needed?
Do I need to reset my router for the upgrade too? I have put in a lot
of settings and if updates comes every few months I can't be resetting
everything from scratch again.
Peter
