R7800 X4S 2.4Ghz signal quality suffering on Voxel 1.02.59SF
5 posts / 0 new
davidm71
Just flashed to Voxels 1.02.59SF and noticed I was having difficulty connecting to the 2.4ghz channel as where I did not before. I also use another Tomato router to analyze the signal quality and its less then my 5 ghz band. Any way to boost the signal with Voxel's firmware?
e38BimmerFN
Try a factory reset and set
Try a factory reset and set up from scratch?
Load NG Stock FW and compare?
e38BimmerFN
I would post here as well:
davidm71
I actually did end up posting
I actually did end up posting there. I'm sure its a channel interference issue. Just have to find a clean channel to use.
Surprisingly the 5 ghz channel is coming in much stronger than the 2.4ghz for some reason.
Voxel
I do not think that level of
I do not think that level of signal was changed in the stock 1.0.2.58 (I use its changes in my 59SF version). The same QCA drivers. So the level of 2.4 and 5GHz signal should be the same.
