I bricked my router and tried USB-TTY method.
It seems succeess however at last, the flash was failed.
After, I reboot my router in order to try to reset again, but it does not respond to both TTY and Lan.
Is there anyway to debrick my router?
which router are you using ??
WNR3500L however I'm not sure it is V1 or V2
This article will help you to idenify your router model and here are the articles to debrick WNR3500Lv1 and debrick WNR3500Lv2. Use accordingly.
FYI the method which I failed to proceed was that method. I tried and got bad flash. However, when I retried, nothing come up on putty screen.
