Tomato completed. In comparison to the software @ Tathagata, PPPoE works, USB works, running lights and front button
http://www.linksysinfo.org/index.php?threads/let-s-talk-about-netgear-35...
i also added new download here, but wait for acceptation.
nice
as i said:
http://www.myopenrouter.com/download/35232/Tomato-by-Shibby-for-WNR3500Lv2/
Hi shibby, very good work, many thanks. Your firmware is what I was waiting for, since I reflashed I'm able to share 3G internet and printer. No problems with flashing, setup from Tomato initial flash by Tathagata Das not-changed. Thanks again.
Could we have the sources of this firmware please?
Kinda disappointed that Tomato no longer easily compiles on modern Linux, that it pretty much requires some early flavor of Mint, a version which no longer readily accesses updates. Sorta signals the finite shelf-life of this otherwise splendid project, with diminishing development. Kudos to the remaining die-hards that continue to build out this marvel, Tomato.
Been looking forward to Shibby's success at incorporating DNSCrypt should he eventually manage that, as he's previously announced his intentions to do, elsewhere. Courage, coders.
sources are available in git repo:
http://repo.or.cz/w/tomato.git
branch tomato-shibby-RT-N:
http://repo.or.cz/w/tomato.git/shortlog/refs/heads/tomato-shibby-RT-N
because I would like to connect a printer and webcam if possible
Printer support is easty to do. Enable Printserver on USB Support page and install new Local printer via TCP/IP port using yuor router ip as TCP/IP port.
About webcam you will need extra modules. You can find it here:
http://tomato.groov.pl/K26RT-N/build5x-083V/extras-mips2.tar.gz
Only cameras supported by UVC drivers will work.
Hi, after install this to my WNR3500Lv2 I cannot get any IP adress from the router.
What can I do? The upgrade process seemed to work. I did saw a new interface. But when I updated the page I couldn´t access it.
Help! :)
EDIT: Works now: Did 30-30-30.. :)
does it works on old wnr3500l?
does it runs on old wnr3500l?
Does it runs on old wrn3500l?
DNSCrypt is now functional in Tomato. Shibby, you rock!
